Coolant temp issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2010, 07:49 PM   #1 (permalink)
Rotary Engine Enthusiast
Tofuball's Avatar
View Tofuball's Photo Gallery
3rd Generation Coolant temp issue
I have a 1993 V6 Camry. Since I got it, the coolant temp gauge only goes up to about 40% on the gauge . The heat blows lukewarm, and the car is always at fast idle (around 950RPM)
I replaced the thermostat and still have exactly the same problem.
What should I check next? The temp stays pegged at 40% once it warms up.
93 V6 Camry Wagon, 86 VW Megasquirted Chevy V6 Vanagon, 75 GMC K2500
Tofuball is offline   Reply With Quote
Old 03-07-2010, 12:22 AM   #2 (permalink)
Custom fab's my specialty
Leviathan66610's Avatar
View Leviathan66610's Photo Gallery
Well 40 percent is normal temperature. As for the high idle try adjusting your throttle position screw near the the throttle body or try spraying starting fluid over the intake areas to see if it revs while its running. If it does then it has a vaccum leak.
92 Camry LE 270,000+ Miles (It will never stop!)
http://www.cardomain.com/ride/3825743
"Everywhere I go, I'm known as the Camry expert."
Leviathan66610 is offline   Reply With Quote
