98 V6 Camry Airbags - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2010, 01:09 AM   #1 (permalink)
TN User
View baber's Photo Gallery
4th Generation 98 V6 Camry Airbags
Hell Experts,
I had a frontal collison and the airbags got deployed. The body shop fixed my car but the collision center guy told me that even though he had replaced the airbags they won't work and the airbag warning light will come up. Needless to say the airbag warning light shows on the dashboard and this is disturbing to me.
I called up toyota dealerships and the airbags there are very expensive $800 each for the driver and passenger. Is there a cheaper way to fix the airbags/get new? If so, can anyone pls. forward the link or guide me.
Thanks a lot !
Best Regards,
Dan
baber is offline   Reply With Quote
Old 03-07-2010, 03:35 AM   #2 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
I can sell you the ones out of my 97 if you want.
Never deployed and the light has never been on.
Chris Crash is offline   Reply With Quote
Old 03-07-2010, 05:45 AM   #3 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
Did they pull the codes from the airbag ECU? If they did, what were they? Did they reset the airbag ECU? It's a different procedure from the vehicle's ECU...
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 03-07-2010, 10:05 PM   #4 (permalink)
TN User
Thanks BamZipPow - I know that he replaced the airbags on the steering and the passenger side coz I see them covered. I do not know if he did anything else however like replacing the airbag sensors and airbag computer.
By the way how to check for the codes in the airbag ECU. I know you can plug in somewhere below the steering column to read the engine codes but I don't know where to plug in to the read the airbag ECU codes.
Can you please advise? Thanks once again all of you for your valuable guidance.
Dan
