Koyo is a decent radiator.
It's best to warm the engine/transmission to normal operating temperature by driving. Then on level ground, after slowly shifting through all the gears and finally placed in Park with parking brake applied, the fluid level should be between the HOT marks. The COLD marks are only for quick reference. I wouldn't trust it for more accurate measurement.
With Hondas I think you check with engine off.
Newer transmissions are more like the VW check method. Except now you have to warm the ATF to within a temperature range and shift through the gears, waiting 3-5 seconds in each, to fill all circuits. Today's LePelletier are picky about ATF level. But those ZF Friedrichshafen transmissions are great and so are the new GM 6 speed Hydramatics.
Originally Posted by redgtxdi
OK, per my previous thread, I completed my radiator swap. Didn't think much of it at the time, but I just did a quick, splash of trans oil (didn't lose much from pulling the trans cooler lines) and probably not even as much as I lost but I figured close enough & I could always fill more.
Radiator will probably need a little more coolant (which makes sense) but my trans oil level is about a good FULL INCH above the full even on the "hot" marks. I had my car worked on a couple of years ago where they dropped the trans pan, cleaned, flushed & filled the system. I assumed they did it right and hadn't noticed even the slightest bit of weirdness in my trans, but could that sucker have truly been that over full for this long??
I dunno....just seeems weird. Maybe the trans cooler path on the new radiator is shorter distance than the OEM or something?? (It was a Koyo)
(shrug) TIA
