Bad MPG, Clunking & Tick Noise
 Instead of posting 3 threads i thought i'd combine it
First problem is Bad MPG. It seems like i'm getting 16-18 mpg city. Is that right or what? I replaced both oxygen sensors, seafoamed the intake and gas tank and replaced the fuel filter about a year ago. Any other ideas.
The other problem is a clunking noise coming from my back struts when i go over bumps. I also get a swaying back and forth. My sway bar moves side to side easily. Are my endlinks bad? or should i replace end links, struts and strut mounts. I replaced the sway bar bushings about a year ago also.
The last thing is a tick noise coming from my driver side axle whenever i put it into gear. Whether its, D or R, i hear a tick noise. Any help on that!
I can do most of the work myself on whatever needs to be done. Just looking for a place to start cheaper.
Daily Driver:1997 Camry LE: Fogs, 2 12" Pioneer Champions 760W Pioneer Amp, Infinity's on Kenwood 4chan, LED interior Conversion, Flowmaster, K&N Filter, 18" A/R wrapped in Continental's
