idle solenoid control motor 96 camry rough starts. help? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2004, 07:32 AM   #1 (permalink)
View sigmachibri's Photo Gallery
ok, parents have a 96 camry with 50k on it. the camry is having a really rough time starting in the morning. it starts for a split second then cuts right off. we took it to be serviced at toyota and the technician told my parents that it might need a idle solenoid control motor. tell me if you agree with his diagnosis before i go and spend the 210 for the part.
here is what happens. turn the key wont really start will staul right out. turn the key and step on the gas for a bit and it will eventually start and idle. the idle is a little rough from then on but with no problems starting till it really cools off again after hours of not being used.
thanks in advance.
sigmachibri is offline   Reply With Quote
Old 03-15-2004, 01:09 PM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
you may want to take out the iac (idle air controller) and give it a good cleaning with throttle body cleaner
-Nick
Nick is offline   Reply With Quote
Old 03-15-2004, 01:23 PM   #3 (permalink)
is there anyone that can give me some idea of where that is? i am very competent with my cars and with general knowledge but as far as what or where the iac is, is a mystery to me. thanks for the help.
Old 03-15-2004, 01:47 PM   #4 (permalink)
Nick's Avatar
on the side of the throttle body, held in by 2 screws i believe,
-Nick
Old 03-15-2004, 07:43 PM   #5 (permalink)
View burchard's Photo Gallery
Search toyotanation for a procedure to clean the air intake control valve without taking it apart. It a very simple procedure
burchard is offline   Reply With Quote
Old 03-16-2004, 02:59 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
http://forum.toyotanation.com/showth...&highlight=iac
"Skoolin' the unlearned!"
Old 03-24-2004, 08:13 AM   #7 (permalink)
ok, sprayed it down, clicked it on and off by unplugging it and plugging it in. still nothing. same crap resulted. i heard the rushing noise the entire time. is it possible that this isnt my problem?
Old 03-24-2004, 09:43 AM   #8 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
there might be a leak in your intake somewhere spray starting fluid over the manifold to make sure i'm wrong
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 03-25-2004, 03:39 AM   #9 (permalink)
View woshiagni's Photo Gallery
I had the same problem, cleaned it out, ran great for one day, and problem came back. Try removing the IAC/ISC valve from the throttle body and give it a good cleaning out in the open.
If it still doesn't start there are some other parts that 88 LE could point out to you...
woshiagni is offline   Reply With Quote
Old 03-25-2004, 06:44 AM   #10 (permalink)
Grenaded piston
88 LE's Avatar
Maybe.
Have you checked the ECT (engine coolant temp) sensor?
10 - 20K ohm (-20C, -4F)
4 - 7K ohm (0C, 32F)
2 - 3K ohm (20C, 68F)
0.9 - 1.3K ohm (40C, 104F)
0.4 - 0.7K ohm (60C, 140F)
0.2 - 0.4K ohm (80C, 176F)
The resistance measurements are between pins 1 and 2 of the ECT.
