Non-Platinum plugs should be fine as long as they are specified to fit (thread pitch, diameter, length and heat range) the number you posted should be fine, but double check the application before buying. There are usually non-platinum plugs listed as alternatives. The plug wires are questionable, but if they look fairly new, they are probably o.k. (some have date codes written on them). You should also check the distributor cap and rotor. Remove it and check the spark gap points inside, replace both as a set if they are burned, pitted, or dirty with scale deposits. Also look for signs of water vapor or moisture inside the cap. Get the cap, rotor, and a new cap O-ring from TOYOTA. Here in Canada I pay only $20.00 for the cap, $8.00 for the rotor, and $2.00 for the O-ring. You MAY find these cheaper aftermarket, but check TOYOTA first, the factory parts will last 3 times longer.
