Motor swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-12-2010, 07:53 PM   #1 (permalink)
View Chuck-T's Photo Gallery
Talking Motor swap
I have a 92 camry le and just wish it would be a little faster i mean its a 2.2 but what other types of motors can i put to replace my 2.2
Chuck-T is offline   Reply With Quote
Old 03-12-2010, 07:58 PM   #2 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
V6 swap. Either a 3VZFE or a 1MZFE. If you've got the funds, do a 3SGTE swap with 5-speed. Hell, just the 5-speed swap will get you off the line faster.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 03-12-2010, 08:03 PM   #3 (permalink)
yeah but it would be nice to keep it 4 cylinder
Old 03-12-2010, 08:10 PM   #4 (permalink)
and what type of toyotas can i get these motors
Old 03-12-2010, 08:13 PM   #5 (permalink)
uibalnme's Avatar
Well, you did ask about a motor swap. Even if you put a newer 4cyl in there, you'll still need to do about the same thing as a V6 swap. You'll need the engine, wire harness, computer, mounts, radiator, transmission, axles, exhaust work, so on, and so on. A V6 swap between your 92 and any 92-96 Camry will be easy since everything from the donor car will fit right into your car.
Old 03-12-2010, 09:06 PM   #6 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
why does that matter? the V6 is MUCH easier to swap then the 3sgte and gets better mileage and reliability.
wanna get really crazy...figure out if the 2.4 2az-fe from the tC will work. it should since it can be had in a gen1 solara, which is the same as a gen4 camry...which has a 5sfe...as well as the gen3. so teh 2az should be able to mount into the gen3.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
