OK Here it is. The Much Anticipated Custom Upholestry Door Panel DIY
This is NOT EASY to get 100% correct. I have done mine twice and Im still not 100% satisfied. With that in mind here is how I did it. I dont have pics from the first time I did it so you will have to bear with me a bit.
First remove all the screws and clips holding on the door panel. Here is a pic of the pieces I had to remove in their relative locations.
Next remove the arm rest and side pocket.
I believe there is 7 screws in the arm rest and 7 in the side pocket.
This is where it gets a little crazy cuz Ive already done it once.
The original fabric should be relatively easy to peel up from the vinyl underneath. This is what it will look like after peeling off the old fabric.
The first time I did this I just traced the old fabric piece I had removed to get the shape of the new vinyl to replace the old fabric. That didnt turn out as I had hoped. So.... This time I decide to peel up the vinyl underneath. Be very careful not to rip the vinyl. This takes a light touch and is maybe the hardest part. Also this was much harder on the driver side for some reason.
Ok now you can spray the front of the vinyl you removed with some spray adhesive and the back of the new material you would like to use. Then simply mate the two materials. Read the directions on the spray adhesive before applying if you have any questions on how to apply it. Once you have the old vinyl and new material glued together simply trim off the excess material from around the old vinyl.
Hint: Mark where the side pocket is and leave some overhanging material to fold over under the side pocket.
Also after doing this twice Ive learned. Leave about 1/16th of an inch of material overhanging the old vinyl. This will allow you to tuck the material into the grooves around the edges of the door panel.
After cutting out all necessary holes this is what the final product should look like. I would also poke or drill holes where the screws go to allow for easier alignment when reapplying this to the door panel.
Now this part is rather tricky also.
Spray the back of the old vinyl piece with the spray adhesive. I also sprayed the front of the door panel in a couple of spots being careful not to get adhesive on the door. Then apply the vinyl to the door panel.
Hint: Use a screwdriver or small putty knife to go around the edges and push in the excess material. You panel should now look similar to this.
Next just reapply the arm rest and the side pocket. Then put the panel back on to your door and You've got a pimp ass door panel upgrade.
Hope you 3rd gen'rs enjoy. And dont blame me when your panels dont turn out perfect. Chances are they will not be. Mine are still not perfect. This is not an exact science. It is difficult. On a scale of 1-10 Id rate this a 9 or 10. Just strictly on the issue of proper fittment.
Enjoy
