1997 V6 Camry P1410,P0446 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2010, 08:08 PM   #1 (permalink)
View web gem 5's Photo Gallery
P0446- Evap charcoal canister, should i be able to just clean this up?
P1410- Egr, should i be able to clean and/or replace sensor?
CE light has been going on and off. esp when i get gas. I never "top off" the thing. usually put 30 bucks in when it goes under 1/4. the 0446 may be my gas cap? it has pressure when i remove it...
Where is the canister and VSV? in the bay I hope.
Thanks, new owner
web gem 5 is offline   Reply With Quote
Old 03-17-2010, 03:31 AM   #2 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
Thanks, new owner
To my recollection, the P0446 is usually resolved by replacing the Charcoal Canister VSV. In my 2000, it is located under the rear of the car, near the gas tank. Check the manuals at camrystuff.com for that information. If you confirm that it is indeed in that location, there are a couple DIY's here on how to replace that VSV (if you need them).
"P1410 EGR valve position sensor circuit malfunction" ... I didn't know the EGR Valve had a sensor. Maybe someone else can comment on that.
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 03-17-2010, 12:32 PM   #3 (permalink)
thanks for the reply.
Old 03-17-2010, 12:41 PM   #4 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Check www.camrystuff.com, Generation 4, Diagnostics section and search down for P1410 -- there's a nice write-up on testing this sensor. Offhand, I don't know how that one is constructed, but if it's just carboned up, you should be able to clean it.
Old 03-17-2010, 07:49 PM   #5 (permalink)
took egr off and cleaned moving parts. cleaned throttle body. seafoamed through gas oil and brake vaccum.
reset and have driven 50 miles, turning car on and off a few times. no ce light.....yet.
