What was the ATF/strainer change history before this?
In L you'll get the help of an additional brake band in the transmission. This helps compensate for the slippage in the clutch pack. The band is wimpy and who knows how long it'll last.
The slippage can be from low ATF (now that's not the case), plugged strainer (that's no longer the case either), low ATF line pressure (various reasons), or simply old, worn out clutch packs. Clutch packs are like your brake pads, they eventually wear out and need replacement.
These Aisin A-series transmissions have no real filtration and are very dirty. The debris in the system acts as an abrasive and causes accelerated wear. The best way to drain/refill every 10-15K miles and periodically change the strainer.
See:
Transmission Swap Write-Up and Photos
This owner last reverse.
Originally Posted by lou1f
I have a 1996 2.2 auto, the trans slips in drive have to get the rpm's up to 2000 before it starts to move but if I use L1 it takes right off already changed filter ans fluid. any ideas?
