idle help and questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2010, 11:01 PM   #1 (permalink)
JDM Inspired
Spitfire's Avatar
Gameroom cash: $122390
View Spitfire's Photo Gallery
3rd Generation idle help and questions
ok so when my car is fully warm, it idles at 750 rpm. as its down that low it tends to chug a little and vibrate the car alot. when i go to take off it even bogs down a little. i noticed though right around 1000 rpm the car runs perfect. no vibrations no bogging or anything i was just curious about these 2 questions
1.is it to much stress on the car to raise my idle to 1k? or maybe up a little higher than 750 so it doesnt shake and bog down?
2. how exactly do you adjust i could never understand.
thanks guys!
Chris
Spitfire is offline   Reply With Quote
Old 03-17-2010, 11:11 PM   #2 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
750 is in spec actually. The repair manual states the idle should be 750rpm + or - 50rpm. 1000rpm is way too high for idle.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 03-17-2010, 11:21 PM   #3 (permalink)
Chemist at Chevron
Gameroom cash: $314885
View bdy0003's Photo Gallery
Are you suggesting to turn your distributor to change your timing?
95 Camry LE I4 195k
bdy0003 is online now   Reply With Quote
Old 03-17-2010, 11:25 PM   #4 (permalink)
#2!
Gameroom cash: $102128
View #2!'s Photo Gallery
Its electronically controlled so it would be much easier to find the real problem and then fix it.
#2! is offline   Reply With Quote
Old 03-17-2010, 11:56 PM   #5 (permalink)
[g4.Rep]
Gameroom cash: $245932
View ONE_to_HATE's Photo Gallery
check your iac valve.
http://i55.tinypic.com/oa6dj8.jpg
[TRD.jpn][TRD.usa][5Zigen][DDM][DENSO][BC][STICH][FEDERAL][STANCED]
ONE_to_HATE is offline   Reply With Quote
Old 03-18-2010, 10:17 AM   #6 (permalink)
JDM Inspired
Spitfire's Avatar
ill look into it more
Old 03-18-2010, 10:17 AM   #7 (permalink)
JDM Inspired
Spitfire's Avatar
maybe its time to clean it with some seafoam? hmm
Old 03-18-2010, 11:08 AM   #8 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
i have some experience with gen4 only, not sure if it applies to gen3 too ... there is an adjustement screw on throttle linkage that allows adjustment of idling speed, but that applies only to non-driving gears (P and N) and computer will take over completely in adjusting the idling speed on any driving gear.
in the end you will have about 1,000rpm while car in Park or Neutral, and still 700 in D,R,2,L at full stop. also such big difference in engine speed will cause harsh gears shifting in parking lot and most likely will kill your engine mounts much quicker (it happened to me). not worth it!
i had asked a friend to do this in past and then forgot, only recently had to revert that "mod" since the effect was bad, long story short the throttle adjustment was causing the throttle plate to stay a little open at idle and it was affecting engine vacuum and causing all sorts of other trouble over time. not a recommended way to go.
as other said, try cleaning TB and IAC with sea foam deep creep and toothbrush. that should fix your idling problem. you might want to replace the spark plugs, wires and filters too as they may affect idling speed as well. checking for vacuum leaks would be also a good idea as this may cause weird things to happen.
Old 03-18-2010, 12:13 PM   #9 (permalink)
JDM Inspired
Spitfire's Avatar
spark plugs were just replaced a few months ago so imma clean the tb and aic today along with my filter if i can get to it now that i have front lip on. might have to bust out the jack. damn CAI's lol
