Security System - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-18-2010, 02:48 PM   #1 (permalink)
Kaddo's Avatar
View Kaddo's Photo Gallery
Security System
Need help (desperately) to disable this annoying thing.
There is no hidden button or switch, as in most cases.
The only thing I can see is a light on my dashboard (left of steering wheel)
labled Toyota Security.
Is this an original, factory installed system?
Any suggestions and comments on how I should go about
disabling it will be greatly appreciated.
(Yes, I checked with the local Toyota dealer; didn't know).
'97 Camry LE, 2.2L, 5-Spd.
Kaddo is offline   Reply With Quote
Old 03-18-2010, 10:36 PM   #2 (permalink)
View KiDGiB's Photo Gallery
Its disabled from factory, atleast mine was til i found the toggle switch. I believe its just a crime deterrent. You could also remove the bulb from the dash if it bothers you that much.
KiDGiB is offline   Reply With Quote
Old 03-18-2010, 11:08 PM   #3 (permalink)
#2!
Gameroom cash: $102128
View #2!'s Photo Gallery
Really from the factory? Anyone have a picture? I wanta see it.
#2! is offline   Reply With Quote
Old 03-18-2010, 11:26 PM   #4 (permalink)
TOYODA KAMURI
the_professional's Avatar
View the_professional's Photo Gallery
Yeah, its right on the left of the steering wheel, if your car doesnt have it, it just has a black "filler".
i love my 1992 Toyota Camry LE 2.2L 5S-FE - 73K
9005 NIGHT GUIDE LOW BEAMS|FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS KA7 3.2L C32A - 87K
SADLY, SHE HAS MUCH MORE MODS...
the_professional is offline   Reply With Quote
Old 03-19-2010, 05:27 AM   #5 (permalink)
Kaddo's Avatar
That light is barely visible, not a problem.
But all that honking and not being able to normally start the engine, are.
Old 03-19-2010, 05:38 AM   #6 (permalink)
Kaddo's Avatar
I have a picture. Just click on my Photo Gallery and you'll see it.
(I couldn't find a way to directly attach it to my posting).
Old 03-19-2010, 05:42 AM   #7 (permalink)
Kaddo's Avatar
So, it's that a factory installed system?
How do I go about disabling it?
Old 03-19-2010, 08:55 AM   #8 (permalink)
#2!
do you have a keyless entry remote? What are you doing to set the alarm off?
Iv personally never seen one but its been mentioned the security system module box is under the drivers seat.
Old 03-19-2010, 09:26 AM   #9 (permalink)
Kaddo's Avatar
No, no remotes with this car.
Also, I couldn't see any box under my seat.
But I'll take another look and report back.
Did that photo tell you anything?
Thanks for trying to help!
Old 03-19-2010, 09:41 AM   #10 (permalink)
#2!
Sorry Iv never seen one of those before so I can't say much. I does remind me of what was in my wife's POS Altima.
My recommendation would be to buy a $30 Valet or Viper keyless entry system. When your only doing keyless entry, the installation isn't bad at all and should be able to disarm your alarm without any problems. The module has a wire you tie into factory alarm disarm wire (Red/Green (-) Driver's Kick Panel White 24 Pin Connector) which sends a ground pulse that disarms the system whenever you press the unlock button on the remote.
Old 03-19-2010, 04:54 PM   #11 (permalink)
Kaddo's Avatar
You were right, I found that box under the seat.
Says on it:
V.I.P. Toyota Security System
Product # 237000 - 1340
I googled it, only RS 3200 models are being mentioned.
They all are remotely controlled and can be programmed that way.
Mine never had a remote transmitter (I just checked that with the original owner).
If so, how can a non-remote system be programmed (disabled) ?
Old 03-19-2010, 05:55 PM   #12 (permalink)
yeah my car wouldnt stop honking at 1:00am in my buddies backyard, so i got a ride home and found my black key, so all i did was reconnect my battery and put the key to on and it turned the alarm off, but down under the dash, where your left foot is located is a plastic corner panel. That is where i found this toggle switch.
Old 03-19-2010, 06:00 PM   #13 (permalink)
Kaddo's Avatar
I checked everywhere. In my case, there is no switch.
Old 03-19-2010, 06:34 PM   #14 (permalink)
#2!
Is there a harness you can unplug from the box?
If so pull it and see if you can still start the car.
Old 03-19-2010, 06:42 PM   #15 (permalink)
Kaddo's Avatar
Yes, there is.
I could see two plugs. One with several wires, another with just one.
