Headlights dimming gen4 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-19-2010, 04:13 PM   #1 (permalink)
View web gem 5's Photo Gallery
97. When I put strain on it with the auto windows, the head lights will dim. Where should i start looking? I have new terminals, about to go on, but wanted some opinions because I read a similar problem and the person had a short. thanks
web gem 5 is offline   Reply With Quote
Old 03-19-2010, 05:01 PM   #2 (permalink)
Gameroom cash: $202300
View zppeacock's Photo Gallery
I have been having the same issue with my es300. I cannot figure it out
zppeacock is offline   Reply With Quote
Old 03-19-2010, 05:37 PM   #3 (permalink)
View KiDGiB's Photo Gallery
I believe that is normal for all cars with auto windows. If everything is dimming really bad, i would start with checking the alternator and battery. You can bring your car to kragen or autozone and they do free electrical testing.
KiDGiB is offline   Reply With Quote
Old 03-19-2010, 05:45 PM   #4 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
My car does the same thing. Did this with my old battery and when I had to get a new one.
I think its normal. Only way to stop it would most likely be a bigger amp alternator, which is silly just for a problem like this.
If I have the fan on high with the lights on for example, the fan spins better with some gas then at idle.
carsrus is offline   Reply With Quote
Old 03-19-2010, 07:56 PM   #5 (permalink)
TOYODA KAMURI
the_professional's Avatar
View the_professional's Photo Gallery
It's a universal thing, not necessarily an issue.
As electrical circuits age, they of course corrode, and don't have as good connections, meaning more draw is required, and your lights will dim.
There is really nothing wrong with your car, if your battery is old, replace.
i love my 1992 Toyota Camry LE 2.2L 5S-FE - 73K
9005 NIGHT GUIDE LOW BEAMS|FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS KA7 3.2L C32A - 87K
SADLY, SHE HAS MUCH MORE MODS...
the_professional is offline   Reply With Quote
Old 03-19-2010, 08:34 PM   #6 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
A slight dimming is normal. But if it's a lot then have your charging system checked for free at Autozone or other local parts stores offering the service.
Old 03-20-2010, 08:54 AM   #7 (permalink)
Newbie
deezeejoey's Avatar
View deezeejoey's Photo Gallery
It's normal. my car did it before I put my HID's in. My cousin's Saturn SL2 does the same thing also.
deezeejoey is offline   Reply With Quote
Old 03-20-2010, 11:28 AM   #8 (permalink)
Gameroom cash: $303255
Perfectly normal.
Mike
Old 03-20-2010, 12:20 PM   #9 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
All cars that I've owned did this after so many years, some worse than others, though.
One thing you can do is to clean all the grounds. There's a ground for the battery to the body, there's a ground for the engine. I cleaned the battery terminals, and all the grounds I could find when I had my Maxima and it was a lot better after I did that.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 03-20-2010, 09:58 PM   #10 (permalink)
PortugalFocus's Avatar
Gameroom cash: $124395
View PortugalFocus's Photo Gallery
I have the same concern on my 00 Camry and on my 05 Saturn VUE. It's not a concern, you have to think you are taking electricity to mechanically move a heavy piece of glass along with regulator up and down about 18 inches. It's a rather large draw on the charging system.
It's no concern at all.
PortugalFocus is offline   Reply With Quote
