Passenger side Windows question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-19-2010, 08:13 PM   #1 (permalink)
View Darkshowdo's Photo Gallery
Well my Passenger side windows have never been working since i have the car.
now im lazy and do not wanna take the panel off to check it.
so hmm could it be something simple like a fuse that doesn't make those work?
my driver sides work.
but not passenger sides.
Or is it the motors?
Darkshowdo is offline   Reply With Quote
Old 03-19-2010, 08:32 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
It's not difficult to remove the door trim panel. On the second try you should be able to do it in about a minute.
Unplug the motor connector and test for voltage supply using a voltmeter. Harbor Freight has them on sale often for a few bucks. Then try connecting battery voltage to the motor to see if it operates.
This way you'll know if the problem is upstream or downstream of that connector (for example, motor or switches/fuse).
Old 03-19-2010, 08:41 PM   #3 (permalink)
Yeh i know its not hard jsut lazy,
so test em ok,
then if no voltage replace it yeh?
and should work lol
with the summer coming up i need my windows lol.
Old 03-20-2010, 06:07 PM   #4 (permalink)
View primo382's Photo Gallery
i don't want to be the bearer of bad news, but if both windows on the passenger side aren't working then you'll probably find some broken wires in the drivers door. All the windows run through the master switch on the drivers door and after years of opening and closing the door the wire insulation becomes brittle and starts cracking. This happened on both my 94 and 96 LE's. It's pretty easy to fix but you'll have to remove the driver door panel, the kick panel on the floor of the driver side, unplug the harnesses from the kick panel and pull them through the rubber boot that spans from the car to the door. Once you do that you'll probably see a half dozen or so wires with cracked insulation and a few that are completely split.
Good luck!
primo382 is offline   Reply With Quote
Old 03-20-2010, 07:03 PM   #5 (permalink)
hmm intresting, i will have to check, but they dont work even when just click them on there side,
i mean doing it with ever windows button i have on both sides.
ill have to check but thanks
what kick panel?
the one under the dash to show the fuses?
Old 03-20-2010, 10:35 PM   #6 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
There is a button right next to the door lock switch on the driver's control panel that disables the passenger windows. Check to see if that button is pressed in.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 03-20-2010, 11:23 PM   #7 (permalink)
what kick panel?
the kick panel is on the drivers side floor to the left of the pedals.
