Window Regulator Repair
The front passenger window on my '97 started to give me some trouble a little while ago. It didn't track right, and needed help to close properly. I figured that the track rollers were worn, and a new regulator was in order. I ordered a new one, and pulled the door panel today. Instead, I found that the regulator was fine, but most of the bolts attaching it to the door were loose; One at the bottom was all the way out, held in place by the plastic liner. Tightening all the bolts solved the problem. I lubed everything and put it back together. I guess the moral of the story is to pull the panel and check it out before you buy the parts.
Chief
