1996 Camry V6 overheating
Hi all,
Scoured the threads, but couldn't find specifically what I was after, so...
My 1996 Camry Vienta V6 is overheating (less than 120K)- here's a bit of the history: The old rad cracked along the top and the car overheated, so i replaced the rad with a re-condiditoned one from Natrad (fairly reliable co.). The problem persisted, so I changed the thermostat. The problem is still persisting, and here are the current symptoms: Car will hold a steady temp. whilst driving (city & highway), but all of a sudden the temp. will spike up to the red, and coolant blows out of the overflow tank. When I turn on the heater to help, the temp comes down, but then hot air stops coming out of the vents, and the temp. rises again. This hot air on/off is intermitent. Also, the idle becomes a bit rough after about 5-10 minutes. I suspect that the head gasket is gone, allowing exhaust into the cooling system, but I would like to draw on the vast experience here to see if there is anything else I should trouble-shoot prior to ripping the heads off.
I have pressure tested the cooling system and it holds 100Kpa with no visible leaks, no worries. I have just read that the thermostat should be installed with the wee pin thing in-line with the top housing stud - something I didn't pay attention to, but will re-align tonight. The top and bottom cooling hoses feel the same temp (i.e. both are hot) when the engine is up to temp (suggesting it's not the pump?). I also plan on getting some test blocks to run in the rad to see if any exhaust gasses are in the coolant. Aside from this, any other suggestions? I have a fair amount of mechanical experience, and could change the HG's myself, but would hate to go through it all and find that the problem was elsewhere all along. Any suggestions? It's a great car, and I would really lament having to get rid of it.
Cheers,
McBrowntrout (p.s. sorry for the length of the post......!!!!)
Reason: additional info added
