possibility??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-22-2010, 10:13 AM   #1 (permalink)
FurrShizzle
View Velocity94's Photo Gallery
3rd Generation possibility???
1994 toyota camry American Made
im just throwing it out there but is it possible i have had alot of engine trouble and to fix my car with new parts is unreasonably high priced. is it possible to fix my car with a Geo Prism possibly?? and the problem i am having is an overheatting issue whenever i go above 55 the vehicle overheats and all my coolant spits out my over flow i am going threw the process of flushing my radiator then i will be doing a water pump fix any idea on how long the water pump would take to remove and replace? just throw me an average if possible and im a first time DIY'er
Velocity94 is offline   Reply With Quote
Old 03-22-2010, 10:34 AM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Time to replace water pump roughly a day for a complete beginner -- it's basically the same amount of work as a timing belt change.
Geo Prizm...not likely...the Prizm was more-or-less a Toyota Corolla...not a lot of crossover to the Cam.
If you have a u-pull junkyard in your area, they're good for a lot of parts. For water pumps, a Aisin (Toyota OEM) from ebay is usually a good choice, and reasonably priced. Toyota thermostat and t-stat gasket are pretty reasonable as-is, and they work well. Radiator...Koyorad makes an excellent radiator, although you can get ebay radiators for dirt cheap, and sometimes they work OK.
The Following User Says Thank You to hill8570 For This Useful Post:
Velocity94 (03-22-2010)
Old 03-22-2010, 11:29 AM   #3 (permalink)
FurrShizzle
thank you very much ninja boy ide love it if u could come wrench my car so i can watch and learn lol but wont happen >.<
