O/D Question/Problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-25-2010, 04:19 PM   #1 (permalink)
View Darkshowdo's Photo Gallery
3rd Generation O/D Question/Problem?
Well ok,
So after yesterday i had time to hook up the o/d button as previous owner put a different shifter on the automatic shifter. upon not hooking up the OD cable.
So now,
I took a part my shifter box found the cord,
now
But now im confused.
So when u connect the two wires, i get OD off on the dash.
So then ok I hook it all up to a switch to the Off postition,
So when i turn the switch off, the OD off light comes on.
I was thinking it was right till this morning.
I decide id see if i was right.
so
when i flip the switch OFF n im just driving. RPM Seems same when im idling.
1) OD off light comes on
2) RPM Go up to like 2k
When i Flip it to the ON position
1) The OD off Light goes away
2) RPM Drops to 1.2k
So i was thinking well i dont know if that rights,
would someone explain please?
or is there something im missing cause no light turn on when i flip it to on position.
Pictures are tooken while i was just sitting still.
But look at lights on dash.
Help would be great to explain this please.
Darkshowdo is offline   Reply With Quote
Old 03-25-2010, 04:36 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Something ain't right about your switch. Here's how it's supposed to work:
One wire (white-with-black-stripe) is ground. The other wire (green-with-orange-stripe) goes to the ECU, the O/D OFF light, etc. When you connect the two wires, you're grounding one side of the O/D OFF light, and signaling the ECU that O/D is off. RPMs should be higher at higher speeds (~45mph) because O/D is off.
If you have a multimeter, check the switch -- I predict what is marked "ON" is no connection between the terminals, and what is marked "OFF" has a connection.
Old 03-25-2010, 05:00 PM   #3 (permalink)
OK so when OD is on should giving it lower RPM right?
n No dash light should be on?
But when OD is off
A Dash light is on, and High RPMS?
I can switch the connection the Switch so , when the switch is on, the OD Off light comes on.
I know the switch is working cause when i turn it on or off, i can see it Raise n Lower RPMS
I guess maybe i was confused on how OD work.
Old 03-25-2010, 05:41 PM   #4 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
I put a different shifter in my car too. I learned that in these cars the stock O/D switch is normally open(off). pressing the button closes the switch(on) and shuts off the O/D. It's counter intuitive, I know, but that's how it is.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 03-25-2010, 05:47 PM   #5 (permalink)
So your saying the OD is Normally Open, meaning its ON?
but when u press the button it turns it off.
well wtf?
thats just stupid.
They want u to get like 18mpg or something XD
Old 03-25-2010, 05:52 PM   #6 (permalink)
uibalnme's Avatar
eh, I got used to it in 30 seconds. I've had my shifter in for 3 years now without any issues. I get ~25mpg city, and ~36mpg hwy. BTW.
Old 03-25-2010, 05:58 PM   #7 (permalink)
lOl i will to now, Ive been driving with OD on i guess forever, wondering why my gas mileages was so bad, lol but now i know lol, Ok XD
I wish i could get that amount, i will have to check how much i get now.
Old 03-25-2010, 06:01 PM   #8 (permalink)
uibalnme's Avatar
O/D on gives you better MPG, not worse. If you're only getting 18mpg with O/D on, you've got other issues. Maybe a heavy right foot?
Old 03-25-2010, 06:15 PM   #9 (permalink)
hmmmmmmmm.....
I see, lol
