1998 Timing belt replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-25-2010, 06:23 PM   #1 (permalink)
View msalcorn's Photo Gallery
I have a 98 Camry and my water pump went completely out and allowed the timing belt to jump time. I have replaced the water pump and timing belt using a kit that included the tensioner. I set the crankshaft on 0 TDC compression stroke and aligned the cam shaft hole with the little dot behind it using a mirror. I rotated the engine 2 full revolutions and tightened the tensioner bolt following all instructions. Unfortunately when I tried to start the car it won't even fire. I checked with a local mechanic and he believes it's still in the timing. I've followed the guidelines and set it severl times. Is there anything else that could have happened to either shut off the spark or fuel to the cylinder. Second, if the crankshaft is at TDC/compression, is it possible to have the camshaft aligned with it's but be 180 off on the valves.
msalcorn is offline   Reply With Quote
Old 03-25-2010, 06:40 PM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
The whole problem is your not supposed to align it with the dot. Rotate cam about 1/8th turn from the dot, or untill it "pops" into place.
The v notch is the timing mark.
Dont worry its a common mistake.
carsrus is offline   Reply With Quote
The Following User Says Thank You to carsrus For This Useful Post:
msalcorn (03-25-2010)
Old 03-25-2010, 08:02 PM   #3 (permalink)
View 05DCLB's Photo Gallery
There is a small notch in gear on crank that lines-up with small mark on oil pump housing{the mark is just to the left of the crank key slot} The top mark is a "u" shaped mark on the cam cap that can be seen thru the hole in cam sprocket.
05DCLB is offline   Reply With Quote
