When installing 6x9 's what goes between the speaker and the car body? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2010, 12:07 AM   #1 (permalink)
View Judge2's Photo Gallery
Should I just get some insulation type foam and put it between the new 6x9 speakers and the body. I drilled five new holes to get the four holes needed for the new speakers, but thought better than installing them without some sort of gasket/rubber/foam type material between the speaker and the car body. What has been used and works well??
Judge2 is offline   Reply With Quote
Old 03-27-2010, 12:44 AM   #2 (permalink)
Night Speed's Avatar
View Night Speed's Photo Gallery
i use dynamat for my speakers. i think it can stop vibration rattles and make my speakers sound better.
Night Speed is offline   Reply With Quote
Old 03-27-2010, 12:52 AM   #3 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
I installed new rear 6x9s and used NO insulation and that was absolutely fine. If you want, you can use some cheapy foam. The12Volt.com may give you some ideas.
edit: dynamat is also a VERY good solution.
'07 Honda Ruckus Big Bore
Old 03-27-2010, 01:15 AM   #4 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
Try these. They are what I have.
http://cgi.ebay.com/ebaymotors/Toyot...fAudioQ5fVideo
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 03-27-2010, 07:03 AM   #5 (permalink)
Gameroom cash: $192100
View SexieWASD's Photo Gallery
I used spray foam then shaved it out inside the hole, and flat on top with a large thin serrated kitchen knife. It worked out very well. I also used long thin bolts + nuts instead of screws, as they hold better.
SexieWASD is offline   Reply With Quote
Old 03-27-2010, 06:01 PM   #6 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
I've never used any kind of insulation. As long as you tighten them properly, you're fine!
Chris Crash is offline   Reply With Quote
Old 03-29-2010, 12:56 PM   #7 (permalink)
View sterfry2004's Photo Gallery
I used silicon caulk. Works well, I just hope I don't have to swap them out anytime soon...
sterfry2004 is offline   Reply With Quote
Old 03-29-2010, 12:59 PM   #8 (permalink)
That's exactly why I never use any sealant on them, if you have to take them out, good luck haha.
Old 03-30-2010, 03:31 PM   #9 (permalink)
4th Generation
Yeah, the decision to do that was a little rash; I just wanted them in. Probably should have waited to make brackets. Maybe by the time the speakers give out, I'll have sold it and someone else can curse my handywork.
