'95 Camry 4 Cyl. Timing belt Part #'s list - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2010, 05:00 AM   #1 (permalink)
View 69GTSport's Photo Gallery
Hi, everyone, I recently bought this '95 4cyl. Camry and have put some work into it, mainly cv axles, serp. belts, oils/fluids changed, and new front brakes.
I'd like to get a comprehensive list of Toyota OE parts to change the timing belt & related componants. I've read the DIYs on the task, but it doesn't list all the OE Toyota part #'s to get everything needed if you want to stay w/ Toyota parts. Is there a Toyota timing belt change kit? Or do you have to buy each item separately?
Here's my list so far that I need OE Toyota part #'s for:
Timing belt
Tensioner
Idler
Oil pump seal
Front seal
Cam seal
Waterpump (comes w/ gasket?)
Also, I have noticed that the engine is noisy when it's ran for a while. I really can't tell where exactly it's coming from. It's a continuous noise but not engine knocking or tapping or anything like that. It's kind've almost like an exhaust leak type of sound, but I can't seem to locate where it's coming from. The engine has around 109K on it. Are there any common issues that these engines have that relate to noises? Do you think it might be the timing belt getting loose? What would that sound like?
1999 Toyota Camry XLE V6.
1995 Toyota Camry LE 4dr. 2.2L.
2009 Harley Davidson Dyna Superglide Custom, customized to suit my tastes .
69GTSport is offline   Reply With Quote
Old 03-27-2010, 05:48 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
You can't visit a dealer to get the part numbers yourself?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 03-27-2010, 08:56 AM   #3 (permalink)
Gameroom cash: $814001
View zythr's Photo Gallery
You can do a Google or Bing Search.
zythr is online now   Reply With Quote
Old 03-27-2010, 12:01 PM   #4 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
http://cgi.ebay.com/ebaymotors/Timin...Q5fAccessories
This is an excellent kit and price.
Timing Kit Toyota Camry Part #
timing belt 13568 09041
water pump 170 1770
timing belt idler bearing 13503 63011
timing belt tensioner bearing 13505 74011
AC drive belt 5PK1105B
PS drive belt 3PK760B
valve cover gasket 11213 74020
four spark plug tube seals 90480 30025
camshaft seal 90311 38046
front crankshaft seal 90080 31022
oil pump seal 15165 70010
thermostat 90916 03046 82
thermostat gasket 16325 63010
oil pump O ring 96721 24020
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
The Following User Says Thank You to csaxon For This Useful Post:
69GTSport (03-27-2010)
Old 03-27-2010, 07:31 PM   #5 (permalink)
Originally Posted by csaxon View Post
http://cgi.ebay.com/ebaymotors/Timing-Belt-Kit-Toyota-Camry-1992-2001-4-Cyl-2-2L_W0QQcmdZViewItemQQhashZitem19b3544e5fQQitemZ110 382829151QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAcces sories
water pump 170 1770
Thanks a ton for that list!
Old 03-27-2010, 08:05 PM   #6 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
That kit is a great way to go. I would also consider replacing the oil pump. The last two 5sfe's I did the pump was worn a bit and I didn't feel like messing around so I just replaced it with OEM part.
71Corolla is offline   Reply With Quote
The Following User Says Thank You to 71Corolla For This Useful Post:
69GTSport (03-28-2010)
Old 03-27-2010, 08:17 PM   #7 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
If you replace the oil pump, you don't need the o-ring or the oil pump shaft seal (they're part of the pump) but there's a gasket that needs to be replaced instead. Or, you could go halfway and just replace the oil pump rotor (since it's the rotor shaft -- where the oil pump seal rubs -- that seems to wear first).
The Following User Says Thank You to hill8570 For This Useful Post:
Old 03-30-2010, 07:13 PM   #8 (permalink)
Thanks for the replies guys. I will be going with a kit on eBay. But I wanted one with all OE parts since they may be the very best quality & last the longest. It appears that everything I have now on the car is most likely still all original and has therefore already lasted 15 years and 109K miles, lol.
Here is the listing I found:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=350328164572&viewitem= &sspagename=STRK:MEWAX:IT#ht_1904wt_935
I will also need to get a valve cover gasket, oil pump rotor?/seal/o-ring, & tensioner spring. Then I think I will be set, hopefully.
Old 03-30-2010, 07:40 PM   #9 (permalink)
hill8570's Avatar
That kit looks to be mostly / all OE manufacturers, but they're not Toyota parts. Not that it's a bad kit, just wanted to make sure you knew what you were getting (since the meaning of "OEM" and "real manufacturer part" tends to be blurred a lot).
69GTSport (03-31-2010)
Old 03-31-2010, 01:47 AM   #10 (permalink)
71Corolla's Avatar
That's true, these parts are not technically Toyota parts. But everything there looks like identical parts to what you would get at the dealer, with the exception of the thermostat (not sure) and of course the AC/alternator belts. It looks like a good kit I would have no problems installing that and trust it just as much as if you purchased at the dealer.
