Fuel Injection services - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2010, 08:19 AM   #1 (permalink)
View schumionbike's Photo Gallery
Is fuel injection service really neccessary or it's just waste of time and money? I have a 181 K miles Gen 4 and I'm thinking of doing it but I like you hear your opinion.
schumionbike is offline   Reply With Quote
Old 03-27-2010, 08:47 AM   #2 (permalink)
Gameroom cash: $814001
View zythr's Photo Gallery
By Fuel Injection service, do you mean cleaning? If so, if you use the right type of fuel then your injectors should be fine. Cleaning is just taking them out and cleaning off the tips that inject the fuel. Over time, crud, and other stuff can start to restrict the flow of fuel from the tip. It's also a good idea to test the electrical parts of the injectors to make sure that they're still firing when they're supposed to.
zythr is online now   Reply With Quote
Old 03-27-2010, 09:06 AM   #3 (permalink)
Gameroom cash: $303255
If you are talking about a dealer or an independent shop hooking up a machine to your fuel rail and/or running a can of fuel injection system cleaner directly through the fuel rail, then my opinion would be no. It's not worth the money. You can do almost the same thing yourself by running a can of fuel injection cleaner through each of the next 2 tanks of gas for a lot less money. I have heard good things about Techron by Chevron. Click and Clack, the guys on Car Talk on public radio, have recommended that product.
Mike
Old 03-27-2010, 09:23 AM   #4 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
I'm with Mike, but do advise to send injectors out for flow testing, cleaning, repair, re-test. You get report with spray/flow before/after and new seals. Of course this may only be practical when doing other related service where it's easy to remove injectors. I've used Witchhunter before with good results.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 03-27-2010, 09:36 AM   #5 (permalink)
thanks guy, yeah I was thinking of a having shop do it with like Mike said. But I guess that won't be necessary, thanks again!!
Old 03-27-2010, 09:40 PM   #6 (permalink)
View 1996camry's Photo Gallery
Stillrunning,
you said you have your fuel injector services at Stillrunning. Did your car makes any different and improve rough idle or smooth performance?
Thanks for sharing w/ other members.
-Andy
1996camry is offline   Reply With Quote
Old 03-28-2010, 06:30 AM   #7 (permalink)
I have not done this to my Camry, but with another vehicle I was doing major top end work on that allowed access to the injectors. I had a leaky injector or two that showed up in a oil analysis as high fuel % in engine oil. After injector service there was no fuel detected in oil.
