Fuse location for 99 Camry Floor shifter illuminator - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2010, 10:34 PM   #1 (permalink)
Gameroom cash: $123900
View dave1811's Photo Gallery
4th Generation Fuse location for 99 Camry Floor shifter illuminator
None of the shift indicator lights on the floor work on my newly acquired 99 Camry. Anyone know if there is a specific fuse that covers the shift illuminator? Read about the Neutral safety switch but wanted to try something simple first. Thanks for any suggestions.
dave1811 is offline   Reply With Quote
Old 03-28-2010, 12:19 AM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Same fuse as radio, A/C and combination meter (speedo, etc.) illumination.
You do realize there is only single "glow" light on the floor shifter (which turns on when the headlights are on)? The only glowing indicator is on the combo meter. The neutral safety switch has nothing to do with any of the lights.
Old 03-28-2010, 08:39 AM   #3 (permalink)
Well, no I guess I misread something about that regarding the NSS. I haven't pulled it up yet. My other 99 Camry LE has shift indicator's on the dash and floor shifter. This 99 CE model just has it on the floor, only one dome, etc. I don't suppose you know the part number or bulb number for the glow light under there is do you? Thanks for the help!
Old 03-28-2010, 08:51 AM   #4 (permalink)
Update--I think I found the part number for that shift indicator bulb and a good diagram of it at:
http://www.toyotapartszone.com/1997/...-retainer.html It looks like it is Toyota part #90080-81309, around $1.00 or under. It will be a cheap fix if I can get it up without took much cussing having big hands.
Thanks!
