water leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2010, 09:21 AM   #1 (permalink)
View matnjav's Photo Gallery
3rd Generation water leak
My 1994 camry with 3.0 is overheating in the area where the belts are at. I would call this the front of the engine. I cant find my repair book but i wanted to ask it is where the the water pump is? I know I'm probably asking a dumb question. I recent replaced the water tranfer hose that was split.It's the one underneath the intake. any help will be appreciated.
matnjav is offline   Reply With Quote
Old 03-28-2010, 10:14 AM   #2 (permalink)
View camry6's Photo Gallery
When you say overheating, do you mean leaking? If you can't see any coolant on the top area of the engine that can run down around that area, then you probably have a leaking water pump seal. The timing belt, tensioner, idlers and water pump are all replaced as a set. This should be done as regular maintenance (check your owner's manual for the change intervals)
camry6 is offline   Reply With Quote
