leaking ignition coil 95 l4????? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2010, 05:57 PM   #1 (permalink)
stlwil's Avatar
View stlwil's Photo Gallery
3rd Generation leaking ignition coil 95 l4?????
been fixing oil leaks latley ,and cant figure out why my dizzy is leaking...not from the O ring on shaft.changed that not leaking from there,it actually seems to b leaking from the ignition coil???the internals of the dizzy are dry.?so i dont suspect the other seal on the shaft on the inside of the dizzy housing...looking through the fsm i see they use fipg when installing the ignition coil to the dizzy......in the past i think my old mech changed out the dizzy but used my old coil ...would him not using the fipg give me this leak main qeustion if seal packing is need is there supposed to b oil in there?????
stlwil is offline   Reply With Quote
