High transmission fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2010, 10:05 PM   #1 (permalink)
Gameroom cash: $115300
View TCam01's Photo Gallery
Hey guys so my transmission seems to have very strong pulls in gears idk how to explain it i noticed that my transmission fluid is at hot on the stick when the fluids actually cold is this bad for the transmission also when it goes from reverse to drive in the mornings it does it too when the engines warm it doesn't seem to have that pep to it anyone have any info on this lol the gear is in park when i check it
Yota Camry 2001 5S-FE 105,430 Miles+
TCam01 is offline   Reply With Quote
Old 03-29-2010, 08:11 AM   #2 (permalink)
View camry6's Photo Gallery
When you check your fluid, you also have your engine idling, correct? Also it should idle 5 min. before checking.
camry6 is offline   Reply With Quote
The Following User Says Thank You to camry6 For This Useful Post:
TCam01 (03-29-2010)
Old 03-29-2010, 09:18 AM   #3 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
^ +1. The level of ATF in the tranny is very important to the way they feel to. Be sure your checking the ATF on a level surface. And yes, if it's too high or too low it could possibly cause the problems you're describing.
'07 Honda Ruckus Big Bore
The Following User Says Thank You to LynchburgCSI For This Useful Post:
TCam01 (03-29-2010)
Old 03-29-2010, 09:21 AM   #4 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Drain it and refill it to the correct amount!
Chris Crash is offline   Reply With Quote
Old 03-29-2010, 04:16 PM   #5 (permalink)
no ive been checking it when its been cold on a level surface while its still in park how should i properly check the fluid
Old 03-29-2010, 04:20 PM   #6 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
The most accurate test is to drive around until the engine is warmed up, then park it on a level surface (keep the engine running), put it into neutral with the parking brake set, and check the fluid level.
The Following User Says Thank You to hill8570 For This Useful Post:
TCam01 (03-29-2010)
Old 03-29-2010, 08:00 PM   #7 (permalink)
Freakin Scooters
+1. Be sure you're on a level surface, and that the engine is ON and at operating temp.
TCam01 (03-29-2010)
Old 03-29-2010, 11:29 PM   #8 (permalink)
ok really appreciate the responses i will do a correct test tomorrow an post what i find
Old 03-30-2010, 12:00 AM   #9 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
When was the last time the ATF was changed? And the ATF in the differential?
