Engine Idle Funny - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-30-2010, 02:01 PM   #1 (permalink)
Newbie
deezeejoey's Avatar
View deezeejoey's Photo Gallery
Engine Idle Funny
My car seems to idle funny but only under certain conditions.
After my engine is already warm. I start the car is starts to jump up and down about a 100RPM. and if I put the car into gear without hit the gas the car jumps with the motor.
If I drive for a little bit it doesn't seem to do it anymore.
Why is it doing this?
It doesn't seem to do this when I start the engine cold (because it idles at like 1300 RPM until the engine warms up)
Edit:
My car is due for an oil change right now. (only have gone 3,020 since my last oil change.)
deezeejoey is offline   Reply With Quote
Old 03-30-2010, 09:36 PM   #2 (permalink)
Newbie
deezeejoey's Avatar
Bump, any ideas?
Old 03-30-2010, 09:55 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
clean the TB inside, plate on both sides and clean IAC hole with a toothbrush. use good cleaner like sea foam deep creep.
How to: Cleaning Throttle Body -4 Cylinder Engines- With Pictures
also post if you have i4 or v6 and what's the mileage.
Old 03-30-2010, 10:05 PM   #4 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426353
View EEngineer's Photo Gallery
does the car tell you jokes when it idles? LOL
jks
anyway, yea cleaning your TB/IAC would be the best idea for now...but judging from your symptoms it's not that bad.
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is offline   Reply With Quote
