97 Camry, splicing wires from non-heated mirror to heated mirror - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-30-2010, 07:53 PM   #1 (permalink)
View PaveHammer's Photo Gallery
Hey,
Did a few searches, but couldn't turn much up, or the wire colours didn't match mine.
Anyway, I've got a 1997 Camry, and need to replace the passenger side mirror. When I purchased a new mirror, what I got was a three wire non-heated mirror, and the original is a five wire heated. I need to splice the new mirror's three wires to the corresponding connector from the old mirror, and need to know which wires are which.
What I've got is as follows:
Old Mirror (square connector, five pins arranged as follows)
1_2
345
1 & 2 are black
3 Yellow
4 Purple
5 Blue
New Mirror (flat connector, three pins arranged as follows)
123
1 Yellow
2 Black
3 Green
I'm assuming that the heated mirror has one wire for the heater and one wire for heater ground. I just need to know which ground is which, and which two wires control the vertical and horizontal movement of the mirror, so that I can splice them accordingly.
Thanks,
Brad
PaveHammer is offline   Reply With Quote
Old 04-05-2010, 01:10 PM   #2 (permalink)
A quick back to top - I looked through a few more wiring diagrams, and couldn't discern which wires powered which motors/heater/ground. Help?
Thanks,
Brad
Old 04-05-2010, 01:12 PM   #3 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Try using a test light. That will tell you the motor and power, and knowing those two will tell you which is ground.
Chris Crash is offline   Reply With Quote
Old 05-30-2010, 03:26 PM   #4 (permalink)
View DC5Max's Photo Gallery
Bump for a update on this?
I bought an aftermarket one (TY) from Eagle Motor Japan (Missisauga) for a 98 Camry.
DC5Max is offline   Reply With Quote
Old 05-30-2010, 03:35 PM   #5 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
Use a multimeter and you can figure out which wire does what.
2007 Camry 2.4L 5M
Old 08-02-2010, 08:32 AM   #6 (permalink)
View wammer's Photo Gallery
Did anyone ever figure this out? I've just installed a mirror on my 97 Camry and have the exact same issue as the OP.
wammer is offline   Reply With Quote
Old 09-15-2011, 05:08 PM   #7 (permalink)
View yche's Photo Gallery
Anyone figure out the wires? I have a same problem. I bought 3 wire mirror but the car has 5 wires. thanks
yche is offline   Reply With Quote
