Trans swap question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2010, 05:02 AM   #1 (permalink)
View lou1f's Photo Gallery
USA Trans swap question
I have a 96 camry 5S-FE with a A140E trans which is starting to slip. Can it be swapped with a A140E from a 92? The manual lists it as the same but the shift solenoid connector looks different. Has anyone ever swapped transmissions is there any other differences?
lou1f is offline   Reply With Quote
Old 03-31-2010, 10:01 AM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
I assume thats going to be because the 92 is OBDI and the 96 is OBDII. Not sure if that affects the tranny wiring or if the solenoids in the tranny are different. TRD4Life probably knows.
'07 Honda Ruckus Big Bore
Old 03-31-2010, 01:26 PM   #3 (permalink)
Thanks for the reply. After further checking it looks like its the park, neutral switch connector. I went into the parts look up and overhaul parts kit for these transaxles seem the same but they list 3 different transaxle assy. I hope TRD4life replys.
04351A GASKET KIT, TRANSAXLE OVERHAUL (ATM)
04351-33010 SXV10..NAP..ATM 1
$235.91
04352A KIT, TRANSAXLE OVERHAUL (ATM)
04352-33010 SXV10..NAP..ATM 1
30500 TRANSAXLE ASSY, AUTOMATIC
30500-33020 SXV10..NAP..ATM 1
30500-33021 SXV10..NAP..ATM 1
30500-33140 SXV10..NAP..ATM 1
Old 03-31-2010, 01:37 PM   #4 (permalink)
Freakin Scooters
toyota part numbers. hmmm....try plugging them into rockauto.com and see if you can't pull up a visual diagram of the differences.
Old 03-31-2010, 02:51 PM   #5 (permalink)
rockauto.com lists the same part # for both years I guess I'm good to go will start next week Thanks for info.
