1995 2.2 Oil seal on camshaft - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2010, 09:58 PM   #1 (permalink)
View davejfitter's Photo Gallery
3rd Generation 1995 2.2 Oil seal on camshaft
1995 Camry 2.2 . Do you have to remove the camshaft to replace the camshaft oil seal? Or can you replace the seal just by removing the timing belt gear on the cam/
davejfitter is offline   Reply With Quote
Old 04-01-2010, 10:13 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
You don't have to pull the camshaft...just the gear. See DIY: Timing Belt + Water Pump + Oil Seal Change - 5S-FE (Part 1) ...down towards the bottom of the description of the procedure.
The Following User Says Thank You to hill8570 For This Useful Post:
davejfitter (04-02-2010)
Old 04-02-2010, 05:34 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
The trick is not to score the cam surface where the seal sits. I bought a special tool that slips in under the lip but does not damage the cam.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
The Following User Says Thank You to Stillrunning For This Useful Post:
