What is the drain and fill capacity of the tranmission 99 camry 4cyl - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-02-2010, 09:53 PM   #1 (permalink)
View steppinthrax's Photo Gallery
I just did a simple drain and dropped the pan. I added in 4 courts of tranmission fluid. I think that's a little too much. What is the fill capacity???
Also does the differential need to be drained?
steppinthrax is offline   Reply With Quote
Old 04-02-2010, 10:47 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
!!!! Haynes states the drain & refill capacity of auto tranny in 97-01 camry (2.2L i4) is 2.6qts
you should drain & refill the differential too while there:
DIY : Differental Fluid Change
loosen the fill plug first to make sure you can actually unscrew it before you drain it (anti-fubar step). differential capacity is 1.7qts.
