Front Axle/Trans Questions.? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2010, 12:41 PM   #1 (permalink)
View Doug S's Photo Gallery
Hi, Looking at myh Daughters 94 Camry V6 auto...
Left outer CV boot is torn, tie rod end boot and inner tie rod boots are also torn. Oh joy!!!
Where is the best place to get these parts, besides the dealer. I want decent quality but the car is old and I don't want to spend 500 per axle.
I also noticed that where the LH axle fits into the trans, it has been seeping a little fluid, it looks to have been doing it for some time and not enough for a drip, just damp around there.
Will this leak get fixed when I replace the axle or is there another seal I need to change...and can I change it?
I searched around here and I think I can handle the axle change, I'm a little confused about the clip on the trans side that you have to force it past. Isn't there a way to loosen the clip?
Thanks
Doug
Doug S is offline   Reply With Quote
Old 04-03-2010, 01:57 PM   #2 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
http://www.lithiatoyotaparts.com/par...?siteid=215542
There's another seal for the input shaft on the tranny side to stop it leaking out...
RichieRichJP is offline   Reply With Quote
Old 04-03-2010, 02:00 PM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
you are referring to the driver's side axle right?
then to answer your question....you can always just go to napa and pick up an axle- should be around 100bucks or so for a cardone axle I believe. you can pick up the differential seal at the dealership and change it when you do the axle.
And no, there is no way to loosen the clip- your best friend is actually a crowbar (use the hooked side), which will give you plenty of leverage to pop the axle out
HaHa
Old 04-03-2010, 05:18 PM   #4 (permalink)
Thanks for the replies.
Those NAPA parts, an issues with them, like longevity?
Do I need any special tools for the differential seal? Or just pry the old one out and seat the new one..
Thanks
Doug
Old 04-03-2010, 07:03 PM   #5 (permalink)
Gameroom cash: $814001
View zythr's Photo Gallery
NAPA parts longevity, depends on how well they're made. Like eveything else car part related if it lasted too long, auto parts stores would be out of business. Your call
zythr is online now   Reply With Quote
Old 04-04-2010, 11:07 PM   #6 (permalink)
TN Pussy Man
^ lol
and if I remember correctly, the seal is pretty easy to change...just in and out
HaHa
Old 04-04-2010, 11:47 PM   #7 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
I had to rent a seal puller to get the seal out...
Luckily, free loaner program at advance was there for me! You do have to pay for it upfront, but you get it back when you bring it back.
Chris Crash is offline   Reply With Quote
Old 04-16-2010, 02:56 PM   #8 (permalink)
Thanks, I have all the parts together, going to do both sides while I am at it..Have a question...
Are there two kinds of axles for this model year? The ones in the car and the replacements I got have 6 large allenhead bolts holding them on to a hub that sticks out of the transmission/differential.
Do I still pry them off and then switch the hub/spline that is in the differential to the new axles?
Picture is worth a 1000 words if you have some...thanks..
Thanks
Doug
Old 04-16-2010, 03:45 PM   #9 (permalink)
rusty9's Avatar
Gameroom cash: $440405
View rusty9's Photo Gallery
the v6 uses the half shafts which you unbolt and replace. but you will have to take the whole thing out anyway to replace the seal.
rusty9 is offline   Reply With Quote
Old 04-16-2010, 08:17 PM   #10 (permalink)
So...just so I'm clear..I can still pry out the whole axle, replace the seal, assemble the new half shaft and jam the whole thing back in the differential..?? No clips to remove??
Sorry, I'm just having a hard time with the crow bar aspect and don't want to break anything...
Is the passenger side any different?
Thanks
Doug
