I am having trouble starting my 1997 Camry with the 5SFE engine. Current mileage @ 193,000 miles.
I have searched and read all posts regarding starting problems but I need to make sure about the symptoms before I start replacing parts on my car.
It just happened today. I had my car for 2 years now and this is the 1st time my car does not start.
Here's what happened:
1. I let a friend to try to start my car and I heard just 1 click from the starter and than nothing after that. He tried to start a few times and I did not hear the click after that.
2. The dash lights all come up with only the digital clock going dim while trying to start. I tried the same thing now with the headlights on and it did not dim at all.
3. The battery posts and starter cables are all secure, nothing lose.
4. The battery is new. Less than a year old.
With my limited knowledge, I am thinking it's the starter that's needs replacement.
Any help is greatly appreciated. Thanks in advance
1997 Toyota Camry LE I4
@ 193,000 miles
Definitely sounds like it's the starter. I had to replace a starter on my friend's 97 5S for the exact same symptoms. Are you replacing it yourself or taking it into a shop?
'07 Honda Ruckus Big Bore TOTALED: '03 Ford Expedition Eddie Bauer 4x4 5.4L, '96 Camry LE 5S May '10: '11 Sienna V6 XLE FWD 8-pass. July '10: '06 Matrix XR Auto FWD Oct. '09: '05 RAV-4 L 4WD
The Following User Says Thank You to LynchburgCSI For This Useful Post:
Thanks Lynchburg, I am thinking to replace it myself. It looks like an easy task plus I have the FSM and TN!
@ 193,000 miles
I'd recommend to figure out what exactly is wrong with the starter. The FSM contains a description of testing procedure. Basically, you need to figure out is it a solenoid (most likely) or a motor itself (less likely). In both cases, you can rebuild the starter yourself. Refer to this topic about restoring the solenoid: DIY--Replace Solenoid Contacts and Plunger on 00 Camry V6
You may buy set of new contacts on ebay: http://cgi.ebay.com/ebaymotors/ws/eB...m=370357378308
If motor brushes are the problem, you can buy them at dealer for $17-23. For example, at partznet.com.
Camry Sedan 1996 LE V6 1MZ - 170 Kmiles
-------------------------------------------------- FOR SALE, Sedan/Wagon parts
The Following User Says Thank You to Nervous For This Useful Post:
Well I know myself and if I can replace the starter successfully, I will be happy!
Not to mention I need the car as fast as possible. But I found a junkyard that has a used starter for $35 and they are open tomorrow.
Thanks Nervous for the link. I am still reading the link you posted and you never know, I might just rebuild it in the end.
You may buy set of new contacts on ebay: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=370357378308
@ 193,000 miles
This is gonna sound crude and low tech but take a hammer and smack the starter a couple times. It should start after that.
Same thing happened with mine. Would start no problem 20 times in a row but sometimes wouldn't start 10 times in a row. Kept a hammer in the car until I replaced it.
The Following User Says Thank You to carsrus For This Useful Post:
+1. You get a few more starts out of her that way.
I read about smacking it in another thread. Well I will try it first thing tomorrow before removing it. But I think I will replace it anyways regardless if the hammer trick works or not.
@ 193,000 miles
check basics first like IGN fuse, EFI fuse and EFI relay (give it a few knocks it might be stuck) other than that manual says more (sorta complicated).
HINT:
Read freeze frame data using TOYOTA hand–held tester or OBD II scan tool. Because freeze frame records
the engine conditions when the malfunction is detected, when troubleshooting it is useful for determining
whether the vehicle was running or stopped, the engine warmed up or not, the air–fuel ratio lean or rich, etc.
at the time of the malfunction.
The Following User Says Thank You to fenixus For This Useful Post:
@ 193,000 miles
