1998 Camry Shaking
1998 Camry V6 XLE auto Tranny
Hey guys Im new to his forum. I have come across a problem with my Camry.When I give it gas as i pick up speed the front starts wobbling like something isnt balanced then it evens out. Its not the tires. I jacked the car in the air and put it in drive and had someone press the gas pedal. What happens is at acceleration the front end shakes. If I remove the tires its still there but not as bad. I already replaced the pass. side CV axle because I have heard that bad CV axles can cause a shake at acceleration. Maybe I replaced the one thats isnt bad.
I looked at the Driver side CV axle where it goes into the transmission and I noticed while its turning the end that goes into the diff is off center. Is that normal? Does this sound like the tranny could be causing the front end to shake? Its not the mounts it doesnt shake in park or neutral when giving it gas. if more info is need please let me know. Im stumped please help me.
your GM cant bet my import
