Ever since my engine swap I've been slowly fixing all the small leaks here and there.
Now that my major leaks are fixed and the oil and grime is being cleaned out from the bottom, I've noticed that the oil pan gasket is leaking pretty badly.
It was covered by all the sludge before that it was pretty hard to see, but now that it's obvious I want to fix it asap.
So I called the dealers and was told that the 3VZ-FE engine never came with an oil pan gasket...it was always silicone gasket maker...
however, i was looking through ebay and found this
http://cgi.ebay.com/ebaymotors/Felpr...Q5fAccessories
looks like felpro makes an oilpan gasket for the 3VZ
which is better? silicone gasket maker or felpro gasket?
