car stalls only at night? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-05-2010, 01:45 PM   #1 (permalink)
View zwfly's Photo Gallery
Question car stalls only at night?
Thank you so much.
zwfly is offline   Reply With Quote
Old 04-05-2010, 01:51 PM   #2 (permalink)
#2!
Gameroom cash: $102128
View #2!'s Photo Gallery
A faulty battery can sometimes cause the engine to stall.
#2! is offline   Reply With Quote
Old 04-05-2010, 01:56 PM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
i say take it out to your local part shop that does free battery and alternator testing, if you think it might be a load issue then check it out
^ and leaving it that way!
Old 04-05-2010, 02:05 PM   #4 (permalink)
Canyon Killer
View ekopel's Photo Gallery
like the men said!!!
haha your car is kind of like the opposite of the night rider!
LOTS OF GOOD 1MZ PERFORMANCE/STOCK STUFF FOR SALE! HERE!
ekopel is offline   Reply With Quote
Old 04-05-2010, 04:40 PM   #5 (permalink)
Gameroom cash: $303255
Clean the throttle body and especially the idle air control valve. A dirty idle air control valve can cause the problem you are experiencing. Here's a post on how to do it on the 5SFE engine. It's for a later version than your's, but it should be exactly the same:
How to: Cleaning Throttle Body -4 Cylinder Engines- With Pictures
Mike
Old 04-05-2010, 05:10 PM   #6 (permalink)
thank you guys, i will let the mechanic check the battery.
actually during the daytime, after engine warm up, it will stall once or two, then switched to "safe mode" or "Default mode". another 5 hours, running great. so wired.
Old 04-05-2010, 05:12 PM   #7 (permalink)
mike, i almost sprayed half bottle of the TB cleaner into IAC hole. still wondering what to do next.
Old 04-05-2010, 05:13 PM   #8 (permalink)
View schumionbike's Photo Gallery
yeah, I would say clean out the IAC, it's fairly easy and doesn't run any risk.
Edit: your engine might have a little problem starting up at first with all that stuff in the IAC but it should be good once it's all clean up. Oh and it's going to smoke a bit too at first, take a few minutes before everything settle down.
schumionbike is offline   Reply With Quote
Old 04-06-2010, 05:17 PM   #9 (permalink)
If cleaning out the IAC valve doesn't solve the problem, I would next check the coil inside the distributor. They can cause problems as they get lot's of miles on them and can fail when they heat up. To do this you will need a digital volt/ohmeter and the specs from any manual. If you don't have a manual you can download one for free at the top of the Camry forum over at AutomotiveForums.com. The manuals are stickied there at the top of that forum's home page. Also inspect the coil for hairline cracks.
Mike
Old 04-06-2010, 09:39 PM   #10 (permalink)
yes, i changed an aftermarket one for just 6 months. i guess i cannot trust the supplier?
