If you have a concern about this, then just start it up in your driveway and let it idle, and watch the temperature gauge. Heater turned off, of course. With the car not moving, there is no air passing through the radiator to take heat away, so eventually the fans will come on to take heat away, but if they don't, your temperature gauge will begin to rise above its normal operating temperature.
Note that your temperature gauge will rise from cold to normal operating temperature before dumping any hot coolant in the radiator. Once at normal operating temperature, your thermostat will bring in some of the cold coolant from the radiator - and it will take a long time to consume that cold coolant before your radiator gets hot to turn on the fans, and before your temperature gauge will move beyond its normal operating temperature if your fans don't come on. How long, I don't know, but maybe 30-45 minutes.
