the dash under the steering wheel? 10mm socket
you should try swapping few fuses even if fuse that is there seems OK.. there can be a break in connection
once you remove the dash under the steering column, get a flashlight and you should be able to see 3 med-size fuses (2 green and 1 pink i believe)
i know one is for the windows, locks, sunroof etc...
Originally Posted by VietPho
Does anyone know what size wrench socket it is to remove golden screw to get the dashboard out?
As for the fuse under the money compartment. I looked at it and didn't see any signs of a blown fuse (broken or black stuff).
Someone in this thread said "15A CIG fuse". Where can I order one online? I've heard these fuses are expensive.
