'Nother 3VZFE overheating problem
I have read several of the posted threads on overheating and through elimination have come to the conclusion the new head gasket not sealing properly.----1994 [see sig for more specs] New most everything, timing belt kit, head gaskets, heads surfaced and pressure checked good, etc. including a new [tested] thermostat, rad caps and radiator. About everything including a new fan switch. It still overheats after ~3 minutes of 2-3k rpm running in driveway or about a mile of driving-30-35/55 mph same result, about a mile and water [no antifreeze until fixed] spurts out overflow into can, overflowing it. A/C condenser allows air flow, heater blows hot.
So my question is, how do you determine which head is bad? And how do you repair it? I know if a cracked head just replace it, but they pressure checked good????Is this a block issue? Used Felpro gaskets so they should be good.
The post from The Camry Man on 3-26-2010 was very informative however I am still confused on the repair of a seemingly small leak causing massive problems. Detest redoing what has already been done if the results will be the same-good money after bad if you know what I mean.
BTW FWIW a close friend has a Toyota cab and chassis with almost the same problem, he has not started his quest for repair.
1993 Camry V6 LE, auto, w/3VZ-FE motor. Paid $250-Found blown intake gasket and both head gaskets.--222k miles.
