Is it hard to change a headlight bulb? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-07-2010, 05:02 PM   #1 (permalink)
View carknight's Photo Gallery
1995 Toyota Camery,2 door coupe,LE.
The driver side headlight bulb is broken.I wonder how hard it is to replace it by myself.How time consuming is it?
I just want to see if that is worthwhile to go to a shop for the work.
Thanks a lot for your input
carknight is offline   Reply With Quote
Old 04-07-2010, 05:22 PM   #2 (permalink)
Gameroom cash: $303255
Most headlight bulbs are pretty easy. If you have the owner's manual to your car it should show you how to do it. Just be carefull not to touch the halogen bulb with your fingers. If you do, you will greatly shorten the life of that bulb. If you do accidently touch it, clean it thoroughly with alcohol and then reinstall it.
Mike
