dizzy o ring wont seal 95l4 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-07-2010, 05:47 PM   #1 (permalink)
stlwil's Avatar
View stlwil's Photo Gallery
USA dizzy o ring wont seal 95l4
please help .iv cleaned the sufrace were it sits in the head and dizzy shaft. tried 3 different o rings from dealer.it just keeps leaking. the dizzy is new and i have no other leaks. should i just rtv it or get an oversized high temp o-ring???
stlwil is offline   Reply With Quote
Old 04-07-2010, 05:55 PM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
I went through the same frustration with OEM o-rings. I finally improved it to almost nothing with a plain buna-n (black) o-ring from NAPA. I've heard that brake fluid swells o-rings and you can try that but there is not much room for a larger o-ring and still be able to get the dist. back in. Take your OE ring to NAPA for comparison.
Don't bother with RTV, I tried, didn't work.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 04-07-2010, 06:05 PM   #3 (permalink)
stlwil's Avatar
i read that this is a 95 model problem somewere
thanks
Old 04-07-2010, 07:24 PM   #4 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Stupid question perhaps, but you sure you installed it correctly? Like, cut the old brittle one out of the slot where it seats on the shaft; put a bit of oil on the o-ring and slide it up the shaft into the slot, then slide the dizzy shaft back into place in the head?
Damn, sounds kind of pornographic
Oh, and the leakage you're talking about is down the side of the engine, right? If it's leaking inside the dizzy, that's a different o-ring (non-replaceable, AFAIK).
Old 04-07-2010, 11:16 PM   #5 (permalink)
stlwil's Avatar
no the dizzy is new
Old 04-08-2010, 09:36 AM   #6 (permalink)
hill8570's Avatar
Originally Posted by stlwil View Post
no the dizzy is new
New or remanufactured? What brand? If it's brand-new, possibly the shaft and seal slot measurements aren't quite right (given what Toyota charges for a brand-new dizzy, I'm assuming you went aftermarket). Remanufactured measurements should be OK.
Old 04-08-2010, 11:08 AM   #7 (permalink)
stlwil's Avatar
reman a1cardone carqeust
Old 04-08-2010, 11:20 AM   #8 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
oh funny, i have the same problem on my 5sfe. it doesnt leak a drop inside the distributor, only from the outside. i replaced the o-ring 3 times with a toyota part but it still leaks. i even checked to see if it could be coming from the valve cover, but its certainly not. drives me nuts because its the only leak i have and i hate leaks.
i will have to stop by NAPA like stillrunning suggested and see if that works.
ghettosled is online now   Reply With Quote
Old 04-08-2010, 11:24 AM   #9 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
I would apply brake fluid on the packing to swell it up. That works really well
RichieRichJP is offline   Reply With Quote
Old 04-08-2010, 12:07 PM   #10 (permalink)
stlwil's Avatar
let me kno if that works <yhe napa 1s> i just got a couple of oversizes o rings from a place here in st.louis called SEALTITE.the oe 1s are like 3.4 mm thick or so .and these are about 4.8 mm. i am going to see if this helps.
Old 04-11-2010, 08:26 PM   #11 (permalink)
stlwil's Avatar
Cool
good news thicker o-ring works. but was a sob to get in
Old 04-11-2010, 09:33 PM   #12 (permalink)
2win2rbo's Avatar
Gameroom cash: $156522
View 2win2rbo's Photo Gallery
I had that problem when I first bought the car. I tried aftermarket o-rings and they weren't any good. Then I went to Toyota Genuine Parts, got the seal waaay cheaper (due to a discount) and that solved the problem.
1993 Toyota Cresta Tourer S JZX90
1988 Toyota Mark II GX71
1999 Subaru Outback 5-speed
2000 Toyota Mark II IR-V
2003 Subaru Legacy BP5 2.0R
2win2rbo is offline   Reply With Quote
