92 camry headlight adjusters - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2010, 12:37 AM   #1 (permalink)
Gameroom cash: $108313
View Slaz's92Camry's Photo Gallery
3rd Generation 92 camry headlight adjusters
so i was trying to adjust my headlights and the adjuster screw jus keeps turning and doesnt move the headlight up or down... any suggestions how to fix it?
Thanx Slaz
Slaz's92Camry is online now   Reply With Quote
Old 04-09-2010, 10:50 AM   #2 (permalink)
Lighting Specialist!
iovaykind's Avatar
Gameroom cash: $480582
iTrader Score: 8 reviews
View iovaykind's Photo Gallery
After so many years, mine hasn't worked anymore either. I've resorted to using foam padding under the assembly to make it higher or lower and its worked for me.. I don't see a fix other than getting a new set. Which is too expensive in my opinion just for adjustment
iovaykind is offline   Reply With Quote
Old 04-13-2010, 11:55 PM   #3 (permalink)
i actually fixed it the other day. you should try taking off the lens and the backing because inside it there are lil gears that move so they can be adjusted
