I was finally able to track down one of these. More unnecessary parts for a car I don't own! Anyways. I know a few of you guys have put these wheels in the gen 3 (Eye8Pussies). Basically I have a few wiring questions. Bunch of threads on this I found searching... but they're all in theory.
Horn: Self explanatory. Splice the old camry wire to the new one on the corolla steering wheel.
Airbag: The new airbag is dual stage. Skip the low speed deploy and wire up the high speed only. (Did someone do this?) I'll have to grab the red connector, correct? As in, the red is the high speed and the black is the low speed, right? The trick is wiring those two wires in the camry's system. I can tap into the camry's airbag wiring here... at the blue and yellow wires:
Basically I need to know if the wiring is blue to yellowy-green stripe / yellow to yellow OR blue to yellow / yellow to yellowy-green stripe. I dont have everything I need to test with me for the next month, so I'm asking.
Cruise Control: The steering wheel I have didn't come with cruise control, so the first step will be dremeling an opening. The next step will be wiring. I'm think i'll use the camry cruise control stalk and wiring, since I KNOW that works on the camry. The trick will be retro-fitting it into the steering wheel. Maybe with custom acyclic plates. It's probably going to end up sticking out at a weird angle... but this wheel already has it like that
I'd prefer to have it closer to an OEM style which you can see below. It sticks out REALLLLLYYYYY far. So this will be a challenge.
You can see that the camry's one is fairly stumpy (below).
Here you can see the holes for where the cruise control stalk would screw in IF this wheel had it. #2 is obscured and you can't see it very well.
Maybe if I hack apart the standard corolla cruise control and swap the circuitry... I don't have one on front of me at the moment though.
'07 Honda Ruckus Big Bore TOTALED: '03 Ford Expedition Eddie Bauer 4x4 5.4L, '96 Camry LE 5S May '10: '11 Sienna V6 XLE FWD 8-pass. July '10: '06 Matrix XR Auto FWD Oct. '09: '05 RAV-4 L 4WD
HAHA! you stole the pic of the wheel I have. The one on the tan couch with the cruise control stalk.
From what I can tell, you'll just have to cut an opening big enough for the stalk to go through. Aside from the electrical connection, the stalks are the same, mounting points, and all.
I think I posted these up a while back...
The stalk at the bottom is the gen3
as you can see the only difference is the harness.
I did A LOT of research, and from what I gathered, it doesn't really matter which wire goes to which. I think of it like model rockets. The power travels through the wires, heats up the igniter, then the igniter sets off the propellant, and that inflates the airbag.
Anyway, that's what I'll be going by.
Man, I really gotta jump on this mod for my car. I've had the wheel for, going on 3 years now, and still haven't installed it. Plus, I have the parts for a rear disc conversion. That settles it...Saturday's going to be a busy day!
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Haha hoped you wouldn't mind! I actually have the COROLLA S wheel.... not the GEN 5 CAMRY wheel like you have. Take a look again at the cruise control on the COROLLA wheel:
It's gonna be annoy as hell trying to figure the cruise out. I need to tinker with the corolla stalk. Junk yard time!
Anyoneeeeeeeee for airbag or cruise insight?
What's wrong with that? Those places are gold mines for us!
Here's a few things I picked up for just the price of admission.
Oil caps with the old school Toyota logo
I'm up to 5 of these things now. The 4 in the pic above, and one on my valve cover.
Every time I go to a bone yard, and don't find anything I really need, I end up grabbing these oil caps as consolation prizes. I grabbed 2 on my last trip to the bone yard!
Okay. Two wires running from the red connector. Which color from the connector to which color on camry's harness?
and they are not regular screws, they are hex tipped
took me a while that all it needs was a hex head...
LOL
Torx T37 or T17...IIRC I took my stock wheel on and off plentyyyyyyy of times.
