That's what I was going to ask and you answered. However, I wouldn't suck on the PCV valve. Petro distillates aren't good for your health. A new PCV valve and grommet is about $10 or so even at the dealer. A new grommet should be used with a new PCV valve. Be careful it can get brittle and fall into the valve cover when you try to remove it.
You first have to rule out external oil leaks -- cam, crank seals, valve cover gasket, spark plug tube seals, and oil pan gasket/RTV seal. If you rule these out, then try a compression test. If you have mechanically inclined friends, get a compression gauge from Harbor Freight, $9.99:
http://www.harborfreight.com/cpi/cta...emnumber=92697
Squirt some oil on the second run to see if the compression increases. If so you have worn rings. However, this checks only the compression rings and not the oil control rings. For example, the oil rings may be plugged up with varnish and carbon.
You might want to check oil pressure using 10W-30 as well. Excessive rod bearing clearance can also lead to oil consumption, because too much oil splashed on the cylinder walls simply overwhelms the oil control rings.
Another source would be the valve stem seals. If you haven't changed these since 93, I think these would be a problem area.
Originally Posted by wally748
forgot something. new pcv valve last spring when i cleaned it along w/the t/b just recently i sucked air from the outlet it shut off right away when i blew the other way a very, very small amount escaped and, i cant remember if thats right or not .
