After a year of having the CEL light as a result of the Auto to manual swap (using a Manual 3SFE ECU instead of 5SFE -_-), I finally decided to have my car OBD scanned to see what else is up...
For over two years now, I've been experiencing an in-cabin gas smell and absolutely cannot get rid of it. I've shampooed my interior at least 3 times since and it always comes back.
Previous to the transmission swap, I did not get an CEL codes. Now, I get the code P0446 - EVAP Emission, Control System Vent, Circuit Malfunction. This leads me to believe that the VSV has completely taken a shit. Maybe??
In relation to this, my car has been running like hell and just an hour ago (yep at 2am, so I was bored) I decided to check my spark plugs and found oil on them. Cleaned them and my car seems to run a lot better. I had been experiencing rough idles which would drop to 400rpm's (not sure if it's completely diagnosed) but this seemed to have helped some after taking a test drive. With this said and in relation to the VSV, could a vaccuum leak from the VSV or somewhere else be split also causing the smell and idle problems??
Other important information: Possible vaccuum leak??? Hesitation when gas moderately applied (not quite WOT)
P0171 - Too lean Bank 1. Possibly faulty o2 sensor, but it's only 4yrs old. Or that the ECU is 3SFE and running a 5SFE motor????
