1994 Camry - I saw this thread and was hoping to see some hints on how to remove the front marker lens/bulb on the sides of the bumpers - but didn't see any. The owners manual says to remove the single screw and then pull out the marker lens. It then appears to show that you can remove the turn signal lens once the marker lens is out.
I removed the screw on the marker lens, but was not able to pull out the marker lens. I didn't want to pull very hard or in the wrong direction in fear of breaking some plastic part.
Any hints on this?
Thanks
