Autozone retails Dorman studs for about $2. These common parts tend to be US-made. So the metallurgy should be fine. I'd do both sides or even all four corners given the mistreatment.
There may not be much advantage in terms of price compared to the local dealer. I mean maybe $1-1.5 a stud maybe? (online dealers are about $2.50 each). I'd just pick up all 20 from the dealer, or check to see if you like the US-made Dorman ones for about $40+tax (all corners) at your Autozone.
Again, for the Autozone Rewards card: on a point basis I think you'll get 1 point for each >$20 (?) of transaction (they need to be separate, for example, you still get 1 point for buying $40 at once). 5 points you get $20 back for store purchases. So each axle set of studs is just a few cents shy, but that's easy to fix
. With online registration you'll get another point. That's 3 out of 5 just for these studs. You buy oils and brake fluids there too, right? In no time you'll get the free $20 spending credit.
Yeah, unfortunately most tire shops can't tighten correctly. Too many are impact happy instead of doing it the right way with torque wrenches. Likewise with crank pulley bolts and wheel bearings.
I'd be careful with the wheel bearing when you hammer the studs out. At least I personally never felt comfortable "persuading" these things. If you can find a ball joint puller that fits the clearance the better. After that you can get several thick washers that will fit the studs. Then put on the lug nut and tighten to spec should do it too.
OEM has a tools that looks like the following, but not sure if they're identical:
http://cgi.ebay.com/ebaymotors/Merce...motiveQ5fTools
(I'm not sure this tool is deep enough to access the stud).
Originally Posted by fenixus
thanks! i can get a set from autozone i guess. should be cheaper a lot.
