I took a look at the cables....they appeared to be adjusted as according to the guidebook you supplied.
I then took it for a drive after checking all the fluids....tranny fluid wasnt blood red like it was when it went in.... several shades darker but not like the dirty brown color when i drained it.
Driving it had mixed results.... Shifting from 1st to 2nd was still a problem....but i noticed after stopping and restarting over a dozen times....that it had different rpms/mph each time it finally did shift. Also at 30mph+ if you nail the gas...it immediately slips and the engine redlines. My brother suggested it might be a sticking valve.... Is there some additive you can put in there to clean it out? or does it require surgery?
Also O/D switch is functioning....and it does lock up as normal. The car isnt displaying any codes that i can tell.... Would a malfunctioning sensor cause something like this?
