rear wheel shakes when off ground, makes noise at highway speed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-12-2010, 01:56 PM   #1 (permalink)
View Camry LE 94's Photo Gallery
I'm assuming it's the bearing... Can anyone tell me what I should/can do from here? Do I really need to bring assembly to a machine shop to get a new bearing pushed in? Or can I buy a new assembly?
1996 Toyota Camry DX [230K]
DEPO Chrome HL's w/ converted Nokya Arctic White 9005 low beams, CF Dash Kit, 14" AR Rims
Advanced Camry DIY'er Noob
Camry LE 94 is offline   Reply With Quote
Old 04-12-2010, 02:38 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
new only way to go, rather easy job
^ and leaving it that way!
Old 04-12-2010, 02:46 PM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
sounds like a bad bearing. if its the front, the only special things you need are a 30mm socket and maybe a 3-jaw pulled to push out the axle from the bearing. in the rear, i think its just standard-size bolts holding it on.
ghettosled is online now   Reply With Quote
Old 04-12-2010, 03:54 PM   #4 (permalink)
Gameroom cash: $139205
View 93celicaconv's Photo Gallery
When you said the rear wheel shakes when off the ground, do you mean when you have it jacked up in back, you can physically grab the wheel and shake it up and down, back & forth?
Assuming this is what you mean (your not driving the car at high speeds over large bumps to lift the rear wheels off the ground, right?), I would be very, very cautiuous on driving it any more until you replace the rear bearing assembly.
Now, you can buy a new bearing and have a machine shop press out the old bearing and press in the new. For almost the same cost of the bearing, you cal also buy a bearing & hub assembly. Most automotive parts stores would have either for you. The removal process is easy. If you have drums in back, just remove the rear wheel, remove the drum, and then take out the 4 bolts holding your current bearing/hub assembly on (you don't even need to remove your brake hardware).
93celicaconv is offline   Reply With Quote
