Question about Rear Motor Mount on Gen 4
Hey,
Anyone change their rear motor mount with the front of the car on ramps? Would prefer to have it on ramps then jacking it up and using stands. Is it possible? Since the rear motor mount is connected to the metal bracket that holds the cv joint for the passenger side, would having it on ramps cause problems in getting the mount out?
Thanks
Update 4/16/10
For anyone who has a 2000 camry, the rear mount isn't bad at all. The main part was getting the top bolt off. With a couple of extensions and 1 swivel joint, you can either use a breaker bar or a impact gun. I tried using the breaker bar but didn't feel like i was going in a good angle, so I decided to use the impact gun. Came out in seconds (Get an electric impact gun). Also had to remove the bolt off the front mount as it was keeping the engine from going up at a certain point. Also remove the dog bone, but you probably knew that.
Some people say you have to remove the cv shaft and other stuff. Didn't have to remove anything to get the rear mount off. Was quoted $160 to remove the rear motor mount, saved some cash there. If you have any other questions let me know.
Also I'm pretty sure that I could have used ramps and would have avoided using floor jacks and stands. Except for the floor jack to lift the engine, but with a 3ton jack you should be able to lift the engine past what you need it to be at. Also just lift the engine enough to clear the top stud, then wiggle the mount to the left or right and remove it. No need to make extra space to clear all the studs (top and bottom).
2000 Camry, 4 Cyl, Auto, Federal, 95k and climbing
Reason: Update
